Frame and engine numbers
Guys the KHI is cast with raised letters into the block and not stamped. All J GPZ serie motors are like this. My J and the Septic are the same
The rest of it looks to be hand stamped with incorrect numbers and spacing
So the stamped numbers should actually begin with KZT00 for the 1000cc and KZT10 for the 1100`s
https://www.z-power.co.uk/merchantmanag ... php?pId=34
Mr Puffin wrote:Guys the KHI is cast with raised letters into the block and not stamped. All J GPZ serie motors are like this. My J and the Septic are the same![]()
So the stamped numbers should actually begin with KHT00 for the 1000cc and KHT10 for the 1100`s
do you mean KZT + not KHT at the beginning of the engine number
