what light is fitted?
- captaincaveman
just wondered if this is off another gpz, quite fancy getting something almost standard looking but without it sticking out from the body work like the original
Jay
81 GPz1100 B1
81 GPz1100 B1
- ZedHead
- captaincaveman
- captaincaveman
- captaincaveman
- captaincaveman
- captaincaveman
tlc wrote:If you just take that bracket off you will see 2 x M8 threads in the rear of the seat rails. Just get a bit of flat on there and mount your lamp.
It's almost as if that's what Kawasaki wanted you to do in the first place.
so literally on the end of the round tubing then? ah ok i thought you'd have to bolt onto where the existing 4 bolts/bracket are? that sounds easy
now a silly question, what happens with the rear bodywork? mines held in place by a bracket with a slotted square rubber mount?
Jay
81 GPz1100 B1
81 GPz1100 B1
- captaincaveman
