Engine Mounting Plate Misalignment
KeithZ1R
#16 PostAuthor: KeithZ1R » Mon Jan 07, 2013 10:30 pm
Z1parR wrote:I've a bracket 58mm downtube centres and 62mm downtube to engine centre .
Thats close enough
:lol:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#17 PostAuthor: chrisNI » Tue Jan 08, 2013 8:23 am
What's the disance from the centre of the eft hand downtube to the centre of the hole on the fixed bracket?
nigel bessant
#18 PostAuthor: nigel bessant » Tue Jan 08, 2013 6:08 pm
chrisNI wrote:What's the disance from the centre of the eft hand downtube to the centre of the hole on the fixed bracket?
Excellent point Chris and one that will solve this problem. The distance is 55mm and on the frame the engine came out of, it is 50 mm.
Therefore, what Gus said is correct, not that I disbelieved him, I just thought the worst and the frame was bent.
Thanks for that pointer Chris it came up trumps.
Thanks to all for their input on this, it has been very welcome.
Nigel
nigel bessant
#19 PostAuthor: nigel bessant » Tue Jan 08, 2013 6:09 pm
PM sent
garyd
#20 PostAuthor: garyd » Tue Jan 08, 2013 8:14 pm
So..did it line up...or do you need a new Brkt made?
nigel bessant
#21 PostAuthor: nigel bessant » Tue Jan 08, 2013 8:47 pm
[quote="garyd"]So..did it line up...or do you need a new Brkt made?[/quote
No, didn't line up but the plate needed wiil be the same dimensions as the fixed bracket on the left down tube.
Z1par has a bracket that from the dimensions, could well be off a shaft frame.
Nigel
Yellow
#22 PostAuthor: Yellow » Tue Jan 08, 2013 9:37 pm
Have this one.
I believe its from a Z1100.
Looking for one to suite a 650 CSR 82. or the measurements to make one.
Cheers.
nigel bessant
#23 PostAuthor: nigel bessant » Tue Jan 08, 2013 10:04 pm
Yellow wrote:Have this one.
Cheers.
I'll check the measurement from the bottom down tube fixing hole to the engine to see if yours would be suitable although I've not heard back from Z1par as yet.
Z1parR
#24 PostAuthor: Z1parR » Tue Jan 08, 2013 11:22 pm
PM returned , bracket here with your name on it Nigel :wink:
0172 . Geoff Parr
Z1parR
#25 PostAuthor: Z1parR » Thu Jan 10, 2013 9:57 pm
Post today , hope you see it saturday :D
0172 . Geoff Parr
nigel bessant
#26 PostAuthor: nigel bessant » Fri Jan 11, 2013 1:20 pm
Z1parR wrote:Post today , hope you see it saturday :D
Top man, cheers Geoff.
Users browsing this forum: Bing [Bot], zed1015 and 25 guests
