Offset front sprocket
- harrythemagnum
Just about to order one, but you never know what members might have spare.
Wanted 5/8" offset, 530 pitch, ta.
What a wonderful philosophy you have,
Sprocket
PUM 451
- harrythemagnum
What gear ratio are you going for with the zzr rear wheel diameter and the sprocket size?
Steve Debben has done this chart which is very useful.
http://z1ownersclub.co.uk/forum/viewtop ... gear+ratio
Gus
Gus
"Set the GRINDER on it"
If you want 17t or 18t Debben will be cheaper..........
http://www.debben.co.uk/acatalog/z1000.html (Scroll down)
Ginger Bear wrote:If you want 17t or 18t Debben will be cheaper..........
Hi Steve
I'm not sure but I think Talon supply Debben.
Cheers.
Gus
- harrythemagnum
Gus wrote:What gear ratio are you going for with the zzr rear wheel diameter and the sprocket size?
Gus
Spot on, just what I needed, ta.
I'll match the ZZR rear sprocket to what offset front I can source.
Gus wrote:Ginger Bear wrote:If you want 17t or 18t Debben will be cheaper..........
Hi Steve
Cheers.
Gus
Gus,
They do, but Debben will get a better price on a bulk order. It's probably only worth going direct to Talon if you want a 19t.
- harrythemagnum
Users browsing this forum: Bing [Bot] and 27 guests
