Z1000R Fairing and headlight brackets
martinz1000r
#1 PostAuthor: martinz1000r » Sun Jan 13, 2013 3:59 pm
Stupid question but been apart for so long I forgot how it goes back together!
Does the brake line splitter bolt on top of the fairing mount and then in to the lower yoke or is it fairing mount, slitter and then yoke?
Can someone have a look and let me know please!
steve.w
#2 PostAuthor: steve.w » Sun Jan 13, 2013 5:46 pm
think it goes on after the splitter :wink:
big green bus
#3 PostAuthor: big green bus » Sun Jan 13, 2013 9:07 pm
steve.w wrote:think it goes on after the splitter :wink:
Steveo is correct :shock:
martinz1000r
#4 PostAuthor: martinz1000r » Tue Jan 15, 2013 2:54 pm
Can some kind soul with a standard ELR please point a camera up under and around the fairing? I cant get all the brackets to line up. Cant find anything in the manual, Kawasaki website parts diagrams not loading and it is the one part i did not photograph when it came apart. Problem areas are the brake splitter, lower fairing bracket, the little bracket on the base of the headlamp just dont seem to want to unite.
Taffus
#5 PostAuthor: Taffus » Tue Jan 15, 2013 3:02 pm
martinz1000r
#6 PostAuthor: martinz1000r » Tue Jan 15, 2013 3:16 pm
Mark, it's not that bit that's causing the woes! It's all the bits that attach to the bottom yoke and headlight shell. Also wondering if I put my headlight brackets on upside down?
Taffus
#7 PostAuthor: Taffus » Tue Jan 15, 2013 3:24 pm
martinz1000r
#8 PostAuthor: martinz1000r » Tue Jan 15, 2013 4:04 pm
Cheers Mark! Just what I needed. I had it upside down and back to front. All slotted back together nicely now.
