my zed bitsa
nanno
#16 PostAuthor: nanno » Sat Feb 02, 2013 6:34 am
Comin' together nicely!
yantosh
#17 PostAuthor: yantosh » Sat Feb 02, 2013 1:04 pm
time was marching on and the blade wheels just made the job much easier, the front wheel needed a new disc centre making to let the caliper clear the spokes(single disc), and possibly a adaptor bracket from the fork leg, which i'm not a big fan of, i know they can be made to look ok, i just prefer not to need them
yantosh
#18 PostAuthor: yantosh » Sun Feb 03, 2013 12:00 am
of course, chopping the subframe meant chopping up a gulliari 2/4 seat, but needs must, i also didn't like the profile of the hump part of the seat so that got re worked with a ballpene hammer using a workshirt as a beanbag to hit it on . i'm starting to like how it looks
i didn't want to use the standard H**** method of holding the front muddie on, so that seemed like an ideal oppertunity to make a fork brace ' i tried to add similar detail to the pockets in the yokes, make it look like proper front end rather than a disparate collection of parts
a rummage in some boxes unearthed a zx6r tail lightwhich is mounted on the abbreviated subframe under the z650 tail
#19 PostAuthor: Pigford » Sun Feb 03, 2013 10:12 am
Usually I'd say its a shame to fudge-up a 2:4 seat, but from what can be seen, that looks ACE :wink:
yantosh
#20 PostAuthor: yantosh » Sun Feb 03, 2013 1:05 pm
i was chopping it up thinking.......gonny get shit for this .......never stopped me mind. i'm sure i have the original cover if its of any use ?
yantosh
#21 PostAuthor: yantosh » Sun Feb 03, 2013 1:08 pm
it was a z9 seat, it didn't fit the z650 tail properly either, i had a pattern z9 tail which i was going to fit but figured that would take away from the fact that i was building a z650 based bike
yantosh
#22 PostAuthor: yantosh » Thu Feb 21, 2013 9:05 pm
the blade wheel wants a 20mm spindle while the zxr arm has 28 mm holes so i knocked up a pair of adjuster blocks with sleeves to take up the slop in the slots
then i had to decide on a headlight, headlights always seem the hardest part, i was going to use a v rod light , but then i started looking at pics of racing Zeds and decided a numberboard was what i needed . but i still needed a light , so i made an aluminium plate and fitted a cbr400 light
and mounted it off the bottom of the top yoke
yantosh
#23 PostAuthor: yantosh » Thu Feb 21, 2013 9:12 pm
figured i better sort the carbs out next, afraid they were looking a little worse for wear
but the lads at MP soda blasting sorted them out, highly recommend them
yantosh
#24 PostAuthor: yantosh » Thu Feb 21, 2013 9:16 pm
then me mate came round to be david bailey
Redbeard
#25 PostAuthor: Redbeard » Fri Feb 22, 2013 11:54 am
cool looking bike, the headlight/no. board looks spot on!
1979 Z1000ST
yantosh
#26 PostAuthor: yantosh » Sun Mar 10, 2013 10:26 pm
cheers mate
bit more done,
i had thought the engine was all mounted.....till the chain tried to eat the top of the arm ...D'oh, so a new set of engine mounts were knocked up , raising the rear of the motor , nicely sorting out that issue
afraid i'm no the best photographer
then i made a top nut that would fit with the adjustable offset yokes
then it was bodywork on and run it outside for a coupla pics
mutz-nutz
#27 PostAuthor: mutz-nutz » Mon Mar 11, 2013 9:32 am
:D that looks well nice is the gsx yours also as it looks rather intresting also pictures please keep up the good work :D
turn full circle and bite ya own arse !!
yantosh
#28 PostAuthor: yantosh » Mon Mar 11, 2013 9:51 am
yeah, i thought it a good idea to do both bikes at the same time ... :shock: :lol:
Redbeard
#29 PostAuthor: Redbeard » Mon Mar 11, 2013 7:52 pm
both bikes look cool, brutal looking zed, nice one. would love a headlight like that for me flat tracker zed.
1979 Z1000ST
yantosh
#30 PostAuthor: yantosh » Mon Mar 11, 2013 11:03 pm
i used a cbr400 headlight , nice and small
Users browsing this forum: Google [Bot] and 9 guests
