Oil
Oil
I know there has been previous threads on this subject but here we go.
I normaly use Castrol GTX 10/40 mineral oil in my z1b however this is not so readily available but a part synthetic version is.
Is this not a good option and if not what would people recomend / where to get it from.
Alan, at my last oil change I refilled with GTX 10/40 and got clutch slip straight away.
200 miles later, drained and re-filled with Castrol Act EVO 10/40 mineral; had no problems since.
Engine Oil
Hi Alan
I had the same dilemma when my source of GTX dried up . I looked at various postings on the forum and did lots of research , settled in the end on Silkolene
Super 4 20w-50 semi synthetic proper motorcycle oil.
This stuff is available from opie oils online at about 30 quid for 4 litres . I had clutch slip issues before with car semi synthetic oil , but this dedicated bike semi synthetic seems fine and all my z's run great on it.
I have stocked up in case they discontinue this too !!
Good luck
Vince
Good luck
Vince
HD/GS/Z1/Z900RS/ Norton
http://www.morrislubricants.co.uk/scrip ... roduct=251
I have stocked up on this stuff,got it for about £9 for 5 litres from a local farm supplies...should be ok
http://www.tfmsuperstore.co.uk/shop/pro ... odID=14335
Here is the link its gone up a bit,think they may have dropped a bollock its cheaper than going direct to the makers,my sheds got a shelf full of the stuff!!!!
- irhobotolo
- Regular Poster
