Gpz1100b2 brake discs
Does anyone know where I can get a new set of good quality front discs for my bike? The originals are scored and a gentle skim will put them below the wear limit thickness and still leave them with only half the pads making contact. I want the discs to look like the originals which rules out EBC discs.
I contacted zpower and was told b1 discs are smaller (270mm against 280mm) and that mine are the same as z1100r discs which are unavailable in the original style.
Dave
Dave
Kent cams, list EBC discs. For some bizarre reason EBC Discs from Kent cams are cheaper than from EBC direct ?
http://www.motorsportworld.co.uk/frame- ... t-cams.htm
EBC direct link - http://www.ebcbrakesdirect.com/bike/par ... 29&sec=Jap
This guy sell / breakes gpz900R bikes and the discs are 280mm and bolt straight on.
I think these are re-manufactured to pattern by him in cast iron and will stop you on a sixpence.
I have some originals on my J1 which he also sells second hand.
I have seen on ebay someone in Hull selling pattern J discs and also a seller called impspares or somesuch who does them as well but cant vouch for the quality.
http://www.ebay.co.uk/itm/Kawasaki-GPZ9 ... 35c3069a7d
Found it; http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 2303e0bb5d
But these will be 270mm, perhaps they also do B2 type!!!
- london calling
- Regular Poster
I know a guy in new York I buy a lot of used stuff from if you cant find any on your side of the pond,Ill look up his email address for ya if you need it.
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
Thanks for all your responses,
I found that most companies offering new B2 discs were in fact selling B1 discs.
I have decided that my brakes need to work effectively and what they look like really doesn't matter! I will order a set of EBC discs tomorrow and hopefully fit them at the weekend.
Dave
Dave
Discs are now on and i have fitted HH ebc pads. Still bedding in but brakes are far better than they were.
I ordered the discs from zpower as they were the cheapest, and the discs arrived promptly, however the disc bolts would not fit in to the counter bore on the discs. I contacted EBC directly, they looked at their technical drawings and admitted the discs were machined incorrectly. They sent a new set the next day which are stainless steel instead of the horrible yellowy colour. They also let me keep the original ones they sent (which would fit very happily if the disc bolts had 2mm machined off the outside edge)
A bit of hassle but a very good company to deal with.
Dave
Dave
I'm sure that the twin disc set up fitted to the 1979 Z500 and 1980 Z400J/550 were taken direct from the GPz1100B2.
I remember this as I bought a Z500 new back then, and one of the selling points were that the brakes were nicked from it's big brother.
Will
Will
Users browsing this forum: No registered users and 83 guests
