switchgear compatability csr 1000
Hi Guys, OK I've just opened the headlight shell to see what tthe state of the electrics are like and some bright spark has cut all the connector blocks off the handlebar switchgear. Does anyone know what bike is compatable ? so I can go on the hunt for some as I only see a couple on ebay and they're in the States, prices aint bad but the shipping is. thanks to all replies, $tevie.
stephen g mackay
Links show compatibility with other models. Rt hand switch gear more common than left ?
46091-1155 HOUSING-ASSY-CNTRL,RH
http://www.partzilla.com/parts/detail/k ... -1155.html
46091-1186 HOUSING-ASSY-CNTRL LH
http://www.partzilla.com/parts/detail/k ... -1186.html
compatability
Thanks Adrian.ADRIAN H wrote:Links show compatibility with other models. Rt hand switch gear more common than left ?
stephen g mackay
