are there inserts available to put a 6mm thread that has been drilled and tapped to 8mm back to 6mm?
thanks
reducing repaired thread
Very timely post. All the threads for the cam caps in the head of my GPz are fooked. A couple previously repaired with helicoils but they pulled out with the bolts.
Will these work for this application? Was looking at Timeserts but my local engineering shop doesnt do them.
martinz1000r wrote:Very timely post. All the threads for the cam caps in the head of my GPz are fooked. A couple previously repaired with helicoils but they pulled out with the bolts.
these may work on the holes with no dowels, when i had the same problem i made up a set of studs that allowed me to keep the dowels in their original positions, i also made up a combined insert with a dowel on them for mr puffin on here, the details are in previous post's, took a while to make the studs but my old bike is still running and out there 7 years later.
