Wheel Bearings
G
Wheel Bearings
#1 PostAuthor: G » Sat Apr 06, 2013 12:25 pm
Hi, Could someone advise the best method for removal of front and rear wheel bearings please .
#2 PostAuthor: PAULJAC47 » Sat Apr 06, 2013 4:55 pm
I just drift them out with a semi circular shaped drift and replace with new ones..
#3 PostAuthor: z1bman » Sat Apr 06, 2013 6:29 pm
these are a brilliant bit of kit better than using a drift as this fits dirrectly into the bearing + you just knock in the tapered tool from the opposite side
http://www.justoffbase.co.uk/Motorcycle ... tAodqmAAAA
#4 PostAuthor: PAULJAC47 » Sat Apr 06, 2013 7:42 pm
Looks a good tool,stick with me drift though made it for nought...
Garn 1
#5 PostAuthor: Garn 1 » Sat Apr 06, 2013 11:06 pm
G, just a quick note..
If it is a front hub of a Z1, Z1A or Z1B, there is a single large circlip behind the oil seal that retains the bearing, this obviously needs to be removed.
G
#6 PostAuthor: G » Sun Apr 07, 2013 11:55 am
Thanks for your help guys. I guessed I would be drifting them out but there doesnt seem to be a lip/point to get any purchase on. Not tried yet though thought best to seek the knowledge on here first.
That tool may be on the agenda if I dont get any joy drifting !
Thanks for the circlip shout too.Its actually an a4 but I have learned something else. Cheers everyone g
#7 PostAuthor: Ginger Bear » Sun Apr 07, 2013 12:18 pm
I was introduced to a bearing puller + slide hammer by young Coldsummer......
Fantastic piece of kit & not that expensive. :up
# 104
G
#8 PostAuthor: G » Sun Apr 07, 2013 12:27 pm
Looks really good Ginger Bear , can you point me in the direction of stockists please
#9 PostAuthor: z1bman » Sun Apr 07, 2013 12:34 pm
G
#10 PostAuthor: G » Sun Apr 07, 2013 1:07 pm
Thanks a lot , very helpful .
gray
#11 PostAuthor: gray » Sun Apr 07, 2013 9:09 pm
Or take a grinder to your existing drift to get a nice 90 degree face on it so it grips better onto the inner side of what you're drifting
Sometimes the tubular spacer between the 2 wheelbearings is very snug and it's difficult to find an "edge" to drift against (so your blind bearing puller won't work either). in that case I lower the drift down till the tip is alongside where the end of the spacer is , and hit the drift sideways, this knocks the spacer sideways a bit and hey presto an edge of the bearing is revealed to drift against.
the spacer can be a pest but don't be tempted to leave it out!
gray
Users browsing this forum: Bing [Bot] and 70 guests
