Two types of valve shim tool - which is best ?
#31 PostAuthor: ADRIAN H » Mon Jan 07, 2013 7:49 pm
Could never get on with the Pro Motion - shim tool - there is probably a knack to using it. But could not get it working for me.
Have a genuine Kawasaki one, found it much easier.
Jeff Saunders
#32 PostAuthor: Jeff Saunders » Fri Apr 12, 2013 2:05 pm
The Motion Pro tool isn't too bad with stock valve springs. But once you upgrade to HD valve springs, the clamp style tool is really the only option.
I have used both, but I use the clamp style tool to change shims in my own bikes.
The factory tool is still available - and always has been. I don't know why some of you think it is rare. We sell it, and I'm sure Marsden sells it too. It's just not cheap... I bought my first one back in 1977 (which I think chrisu might have now...). We have a replica of that tool as well - we had them made as there's no telling when Kawasaki will discontinue the real one.
#33 PostAuthor: kev edwards » Fri Apr 12, 2013 2:22 pm
Its because they are tightwads :wink:
#34 PostAuthor: chrisu » Fri Apr 12, 2013 3:49 pm
Jeff Saunders wrote:The Motion Pro tool isn't too bad with stock valve springs. But once you upgrade to HD valve springs, the clamp style tool is really the only option.
yes i do and its still giving sterling service....... :)
