Engine builder Kent area
Hello, can anybody recommend an engine builder in the Kent or South East area please? Cheers. Pete
Thanks so far - but I didn't make myself very clear about what I was looking for.
Basically, I'm pretty hopeless at mechanics etc. So I'm looking for a reliable place that will check over my Z1B top end (pistons, rings, valves etc.) and replace what needs replacing without ripping me off.
There seems to be some good places around the Midlands, but I don't know of anybody in South East.
Cheers. Pete
Cheers. Pete
If it's still in one piece starts and runs fine run with it, set up the valve clearances, timing, then compression test it, the compression test will give you an idea of the engine condition,
How many miles on it?
There are a few bike places in our area but no specialist rebuilders, i have always done most of my own work, but if i had to have any valve seat cutting i took it to dartford rebore.
I could always come to you and check valve clearances, timing and compression test the old girl if it's in one piece, i'm only up the road in Walderslade.
