Z650 into 810 project
Don't know about sunshine jon, looks like you must have a fair bit of white stuff on the ground right now.
No snow here, just very cold.
I took delivery of the front brake hoses today, had a company off ebay make them. They do kits, but if you message them they will tailor the length to whatever you want and can specify different threads for the caliper bolts etc.
They are Venhill hoses, but the company is called 'Up The Shop'.
Great service
Great service
Filled it with oil tonight, kicked it over and got oil light to go out. Fitted battery and it spins over nicely, just need some petrol and the plugs and I can try to start her up.
Bodywork needs to be sent away for refinishing.
Hoseclips and a hose needed for rear master cylinder and its rideable, whohoo!
Just got back from a 2 mile test ride, all seems fine except the plugs are showing the mixture to be rich. So will be playing around with the carbs this week. Seems to pull very well through all the gears and the transmission is smooth after rebuilding the clutch basket.
Here is a vid of the bike after I took it for a ride.
Click on picture to watch.
re the filter Mark, already thinking I may go K and N dual type filters.
Had it running again today, without the breadbox filter which has helped lean it off a bit. I also finally wired in the rev counter and found it has a nice feature, see vid
I have boxed up the bodywork and its off to Flying Tiger tomorrow.
Royalratch
