I'm not too sure ill be liked around here............
#91 PostAuthor: Ginger Bear » Sat Mar 30, 2013 8:58 am
Can't find 4549, but have found these....
http://www.wiseco.com/ProductDetail.asp ... AppID=7203
Dig around a little more & you'll find exactly what you've got.
# 104
kiwi kdx
#92 PostAuthor: kiwi kdx » Sat Mar 30, 2013 10:30 am
Yeah I have been doing a bit of hunting and I can't find 4549 either, I have plenty of time though and it all depends on the bore's and how much work they need.
#93 PostAuthor: Al » Sat Mar 30, 2013 11:16 am
KIT 1105CC KZ1000J / R, S523 CW17 4549PS XA/C2874 (+3.5 MM) W3918J
001-K1106
(+3.5 Mm) (+3.5 MM) W3918J
WISECO PISTONS:
This brand of high nottoriété we distribute since 1977 offering the largest range of forged pistons for motorcycles.
A passion for performance.
http://translate.google.co.uk/translate ... CDoQ7gEwAQ
kiwi kdx
#94 PostAuthor: kiwi kdx » Sun Mar 31, 2013 3:50 am
Pulled the bottem end down this arvo and in super happy with what I have found.
-clutch looks mint
-crank looks mint
-gears look mint
In fact it looks like a brand new bottom end!
And this is how my shed looks at the moment, I'm going to sort out some form of work bench tomorrow.
#95 PostAuthor: Pigford » Sun Mar 31, 2013 8:38 am
There you go - it's all MINT - coz its KAWASAKI :twisted:
kiwi kdx
#96 PostAuthor: kiwi kdx » Mon Apr 01, 2013 2:53 am
"nobody beats super a mart"
Even for garage work bench's..... Got a new dining table with one chair for $89!
I couldn't even buy the material to build myself a bench for that.
Where are my head studs you ask?
So I cleaned all the gaffa tape off my bearing surfaces and the next step is to clean all the glass beads out of the oil galleries, I don't wan any of those little bastards floating around!
kiwi kdx
#97 PostAuthor: kiwi kdx » Sun Apr 28, 2013 7:10 am
I missed out on a set of Makuni flat slides on egay the other day they went for $280!
I'm sure someone here scored them....... But after thinking about it, I want to eventually
Use this bike as my daily ride so the The Mikuni BS34's I already have are probably better suited
To give me the smooth response I'll want.
So I pulled them down today, overall in pretty good nick! 2 split diaphrams and that's it.
A box of bits;
Soaked Emma for a while:
After a quick scrubb to get rid of the "all black" spray job some dickhead gave them:
They still need a good clean, Im deciding weather or not I'll buy a little ultrasonic cleaner.....
kiwi kdx
#98 PostAuthor: kiwi kdx » Mon May 06, 2013 2:40 am
moving along... i washed out all the little glass beads today, ran the hose through the oil galleries with simple green for a good 5 mins.
got the selectors in the new clean cases:
and got the bottom end tucked away:
#99 PostAuthor: Pigford » Mon May 06, 2013 7:49 am
Nice when the clean bits & pieces start getting thrown together.... :wink:
kiwi kdx
#100 PostAuthor: kiwi kdx » Sat May 11, 2013 11:10 am
So I picked up Betsy the parts bich today (not really many parts left.....) I'm pretty happy with what I scored but also a little confused
Here she is:
It's got whats left of an 1100 donk:
And someone has welded in some bracing and a lower engine mount that as far as I know the Z1000ST never had
So could this be a GPZ motor? Coz they have the second lower front engine mount:
They have also done the bracing down the back bone, bounes!!!
And I got my cast engine mounts!!!!!
