K&N type Engine breather
stempy
#1 PostAuthor: stempy » Fri May 03, 2013 6:04 pm
Has anyone had any issues with fitting K&N type Engine breather :oops:
PUM 451
#2 PostAuthor: Ginger Bear » Fri May 03, 2013 8:57 pm
Rick,
Only problem I had was fitting one too low, with an APE breather cover without baffles. :shock:
It was fine whilst taking things steady, but once I gave it 'the beans' the oil couldn't get out fast enough. :evil:
Solved the problem by fitting a taller pipe, similar to the one in your pic.
# 104
firyembers
Custard Creem
#3 PostAuthor: firyembers » Sun May 05, 2013 11:44 am
did the same with a halfords filter,but dropped a ball bearing in like t section pipe to act as a one way valve to help solidify oil mist back to chamber.
Not sure yet if its helping with my total oil loss i seem to be having,as it was an open air system prior :D
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
Users browsing this forum: No registered users and 100 guests
