1 check the alarm fuse
2 check batteries in remote
3 press + hold both buttons for 5 seconds
4 re program your remote
5 replace the pcb at a cost of about £100
battery charging
z1bman wrote:1 check the alarm fuse
Done the checks yesterday,
Fuse OK, Both fobs seem to be working good, stripped it down to "drain" after a "Spike", pressed both buttons several times in several combinations (both thumbs are sore today!!).
The problem is that it does not bleep and flash to disarm. I can crank over with NO ALARM at all. If I shake it the alarm and indicators go off. If I untape the seat micro switch the alarm goes off.
When I press the fob I can hear the box clicking inside.
I think I have a buggered black box????
Jimmock.
I hate people I don't like !
jimmock wrote:z1bman wrote:1 check the alarm fuse
Guyz,
After reading my post ...........
I suppose it would be worse if I had a buggered back door!!!
Jimmock.
z1bman wrote:yes 99% sure your pcb is shot you don't have to remove the complete alarm if you want to get it running just remove the pcb + short across the emobolized wires on the two block connectors if you want to know how + which wires to short let me know + i will send you a pm
Z1Bman is a LEGEND.
He sent me a PM with a pic.
BLADE IS NOW RUNNING!!!!!
I owe Z1Bman a couple of "sexual favours" !!!!
Jimmock.
