Jet needle
- steve bowdler
Jet needle
Had a little problem ! carb would not shut off when throttle released suspected cables but on removing cables carbs still sticking.
Removed carbs off bike and cleaned , noticed some crud on one of needle vales now the question how robust are these needles , will the tolerate a good scrub or best replaced ?
- steve bowdler
I'm getting simular probs with mine. Starts up and ticks over/revs fine but when it gets hot the revs take a while to drop back to tickover, sometimes staying at 3000rpm, Ive fitted new inlet rubbers (so no air leaks) and new jets/needles etc have been fitted.
Was thinking maybe its the float heights. All cables etc are free etc.
Might be worth sending my carbs away to someone for cleaning and setting up,
any ideas anyone.
ta very much.
any ideas anyone.
ta very much.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
zxr750 m2,
zrx1200
- steve bowdler
- steve bowdler
Probably too obvious Steve but have you checked all the slides are at the same height when shut ? only pointing this out cos I had mine off and apart recently but didnt check em before I put em back, same symptoms as your goodself
when i checked one of em was a good half mil+ higher when shut some small adjustment from the top so they all had the 2mm gap (on mine) at the inlet throat cut out problem solved
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- DogsbolloxofZ1B
Taffus wrote:had the same on my GPz 1100 carb conversion and yes, it it was float heights. somehowI had added a 1mm to the height from the carb base to the floats (carbs inverted) corrected this and the hang was gone....
Interesting - but I'm surprised that made any difference - especially as it would lean the mix out slightly
hi, carbs will need to be mechanicaly balanced, there is an important measurement between the throttle cable quadrant and the cable guide, this must be correct first, then mechanicaly balance the carbs as per manual, then once back on the bike, check balance with vaccume gauges if you want
hope this helps tricky.
