A Carb option question
GPRD
#1 PostAuthor: GPRD » Fri May 17, 2013 8:43 am
I've got a GPZ750R1 engine that is getting rebuilt with an 810 kit. I have also just come across a set of 28mil Mikuni's.
My question is, will the 28s be a better option to run with the 810 engine, or should I stick with the BS 34s?
Gary
What we got here, is failure to comunicate.
#2 PostAuthor: Pigford » Fri May 17, 2013 8:52 am
If the carbs are going to need tuning - always easier with proper "slide" carbs (ie: 28mm) rather than the CV type :wink: Depends what else you're doing/fitting to the motor :!:
GPRD
#3 PostAuthor: GPRD » Fri May 17, 2013 9:47 am
Thaks for the reply.
I guess they're going to need some sort of tuning as there will be no standard settings for the set up, so I guess 28mm is the way to go.
I'm not going to be doing anything else to the engine in a tuning kind of way.
Users browsing this forum: Bing [Bot] and 74 guests
