here attached images of my bike.
today was the first ride after the mechanic made the tuning of the carbs.
few problems:
- oil pressure light is on when rpm is below 2000. I have removed the oil pressure switch for cleaning but problem is not solved. According to the mechanic nothing wrong with the oil pump. I have ordered new switch.
- engine doesn't restart easily when hot. Need to cool down to restart.
Acceleration is fine. brakes ok.
ciao
https://www.dropbox.com/sh/io1ep8mluhl49qk/7uUviY1VUo
finally on the road...
- Mark Stratton
Re: finally on the road...
alinus65 wrote:here attached images of my bike.
few problems:
ciao
Really nice looking bike.
I had the same issue with the oil light coming on when idling when I rebuilt my Z1000 a few years back. That was a simple case that I had forgotten to fit the "o" ring between the sump pan and the lower crankcase. Once fitted oil light went off when the engine was running at any speed.
