A4 silencer problem
bedlow1
A4 silencer problem
#1 PostAuthor: bedlow1 » Tue Sep 04, 2007 10:39 am
Hello, I have just obtained a used carb silencer for an A4 item 15 on the diagram. The problem is that the packing material is shot and resembles biscuit crumbs. Does anybody know if there is a modern material you can use to repack? Also I need the clip and screw 14,16 to secure it to the airbox which is NLA any ideas?
1972 Z1 Euro Spec
1975 Z1B UK Bike
Davy Doherty
#2 PostAuthor: Davy Doherty » Tue Sep 04, 2007 8:34 pm
Use thin foam from an upholsterer and a jubilee clip job done!!
bedlow1
#3 PostAuthor: bedlow1 » Tue Sep 04, 2007 8:57 pm
davey, thanks for you input i will give it a go
1972 Z1 Euro Spec
1975 Z1B UK Bike
prowlerz1
silencer
#4 PostAuthor: prowlerz1 » Tue Sep 04, 2007 9:19 pm
go to any motorcycle chop and buy a sheet of airfilter foam they are about 1ft square cheap as you like and use that it can then be washed periodically and reoiled
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
