Exhaust smoke after throttle shutdown
- z1000puddin
Guys,
I had a hundred or so miles on my 1075 zed. yesterday.
My mate following noticed that there was smoke coming from the exhaust when the throttle was shut-down. Noticeably when it was getting a good thrash.
The bike has new MTC piston & rings
28mm carbs with 112.5 mains & 17.5 pilots.
Open ally trumpets
Intend getting it dynod, but I am concerned about the smoke - Should this happen on a rebuilt motor ??
Or should I carry out a compression test. ?
The bike starts & idles well, pulls well although it may need a jet up one or two.
.The bike has done a couple of hundred running in miles.
Stu
Open ally trumpets
Stu
Zed til Dead
- z1000puddin
PaulMceleney
- Chunks
- z1000puddin
PaulMceleney
- Chunks
- z1000puddin
PaulMceleney
- Chunks
- z1000puddin
PaulMceleney
- Chunks
Charlie wrote:How much smoke and what colour is it ?
I would go back to this before deciding to play with carbs. Blue = Oil, Grey/White =Rich mixture which, looking at your plugs, I would say is not your problem.
I am not sure if leaking oils seal will show on a compression test? The blue smoke on over run is usually due to the increased vacuum when the throttle is shut off sucking oil passed leaky seals on the inlet side.
Users browsing this forum: No registered users and 162 guests
