gpz clutch
johnA
gpz clutch
#1 PostAuthor: johnA » Sun Jun 23, 2013 10:10 pm
hello gents could anyone help me by telling me what position the clutch actuator arm goes on a gpz1100 unitrack please.having problems adjusting it using the cable was wondering if this was in the wrong place.many thanks in advance john
big green bus
#2 PostAuthor: big green bus » Mon Jun 24, 2013 6:37 am
It can really only go in one place, I had prob's with mine and it turned out to be a warped clutch plate, no matter how I adjusted it the clutch would drag or slip and the free play would loads or none without touching it.
#3 PostAuthor: z1bman » Mon Jun 24, 2013 9:02 am
you need to adjust it at the screw + lock nut in the sprocket cover then put the required free play by adjusting the cable adjuster
johnA
#4 PostAuthor: johnA » Mon Jun 24, 2013 4:23 pm
cheers for that i adjusted the clutch at the casing first as per handbook then the cable but its still biting right at the end of the travel are the plates on the way out then.
Users browsing this forum: Kwackman, moizeau and 39 guests
