Seal part number
Seal part number
#1 PostAuthor: Al » Sun Jun 30, 2013 9:35 pm
Looking for the part number for the seal on the bottom of the handling reservoir please. Mine has worn at the internal diameter.
Also who does the handling pumps and is the one available through the club.
Any help appreciated.
#2 PostAuthor: z1bman » Sun Jun 30, 2013 11:03 pm
what is a handling reservoir?
Garn 1
#3 PostAuthor: Garn 1 » Mon Jul 01, 2013 12:55 pm
Yeah! what is a handling reservoir? Handling pump?
RegardZ
#4 PostAuthor: ZedHead » Mon Jul 01, 2013 5:38 pm
Do you mean chain lube tank and pump?
#5 PostAuthor: ADRIAN H » Mon Jul 01, 2013 5:40 pm
I am confused ? ttiw
#6 PostAuthor: Al » Mon Jul 01, 2013 9:12 pm
Fitted new forks to the J which turned out to be straight (thanks Padders) but they caused the throttle valves to jam wide open particularly on long sweeping bends leading to near catastrophic failure of the handling reservoir rear lower seal.
Thanks for the offers via pm to prise apart the hemispheres, ream out the old seal, drive home a new one and pump the system back up to pressure,... i may have to go that route but for now it seems to have tightened back up OK.
PostPosted: Mon Jul 01, 2013 6:40 pm Post subject:
I am confused ? wotnopics
Adrian i'm shocked is all i can say :shock:
spondonges
#7 PostAuthor: spondonges » Tue Jul 02, 2013 9:11 am
Do you mean "Steering Damper" ???
I'd rather be riding my Z1 thinking about God than sitting in a church thinking about my Z1..
AndyZ1R
#8 PostAuthor: AndyZ1R » Tue Jul 02, 2013 6:50 pm
I think I may have one that I took off a few years back and never used, I`ll try and check it in the week.
steve bowdler
#9 PostAuthor: steve bowdler » Tue Jul 02, 2013 7:08 pm
AndyZ1R wrote:I think I may have one that I took off a few years back and never used, I`ll try and check it in the week.
A used one :shock:
#10 PostAuthor: Al » Tue Jul 02, 2013 9:56 pm
Been out in the garage and the bike has a flat front tyre so it was a puncture.
Thanks for all the useful suggestions and offers.
Garn 1
#11 PostAuthor: Garn 1 » Tue Jul 02, 2013 11:46 pm
Zorded you are usually so precise in your descriptions and technical expertise. What went wrong this time....
I'm still trying to work out the terms "Handling Reservoir" and "Handling Pump".
I don't think you are talking about steering damper!
I don't think it's brakes!
I don't think you are talking about front forks... Perhaps, maybe some internals of the J front forks? Would appreciate an explanation slow time.
RegardZ
steve bowdler
#12 PostAuthor: steve bowdler » Wed Jul 03, 2013 7:20 am
Garn my theory is when some times a bike miss handles and causes the rider to Fu**in shit himself , then this so called part thar Zorded is looking for has failed :oops:
Hope this is right or am I barking up the wrong tree !!!!!! :oops:
Garn 1
#13 PostAuthor: Garn 1 » Wed Jul 03, 2013 11:24 am
OK! I get it!
A little like "my poofer valve is broken!"
Thanks Steve.
#14 PostAuthor: Al » Wed Jul 03, 2013 6:03 pm
Just as Steve says; the fastest way to loose weight i know.
Thanks for all the help and apologies for any confusion caused.
Users browsing this forum: FOZ1A, kawasaki_man and 68 guests
