Wanted ignition/points housing for Z1000J Z1100r Gpz1100
Padders
#1 PostAuthor: Padders » Sat May 25, 2013 6:20 pm
I am looking for the ignition/points housing for a Z1100R I understand the Z1000J and GPZ1100 ones are the same. Right hand case that the points cover fits onto.
The one on my engine has had the usual gobo repair
PUM 13
london calling
#2 PostAuthor: london calling » Sun May 26, 2013 5:17 am
Might be able to help Brucie :wink:
Jack
Darren Williams
#3 PostAuthor: Darren Williams » Sun May 26, 2013 12:22 pm
Hi Ian, just spotted this on ebay 160938248239. As yet not found one in the garage.
Regards Darren
phil le brocq
#4 PostAuthor: phil le brocq » Mon May 27, 2013 11:33 am
When I built up my GPZ1100 motor I had to repair my original J case to use the J pickups as the GPZ housing had different internals, worth checking! I don't know about your model, but I still have the GPZ case, very scruffy but intact, would polish if this helps.
Phil.
elr-21
#5 PostAuthor: elr-21 » Tue May 28, 2013 8:12 pm
Hi there,
please note: this one for Z1000J/R-GPZ1100B1/B2 is another one as the Z1100R!!!
As well the housing as the pick ups are different. For your Z1100R you will need this one of a GPZ1100UT!
KERKER kicks ass!
firyembers
Custard Creem
Re: Wanted ignition/points housing for Z1000J Z1100r Gpz1100
#6 PostAuthor: firyembers » Wed May 29, 2013 8:24 am
Padders wrote:I am looking for the ignition/points housing for a Z1100R I understand the Z1000J and GPZ1100 ones are the same. Right hand case that the points cover fits onto.
I have the original GPZ1100 A4 housing which is the later type,as opposed to the earlier type same fitting to crankcase but has 3 mointing points for ignition plate
Sent a piccie via eMail
Cost of postage will do me,in July when i get back if you can wait that long
Regards
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
Padders
#7 PostAuthor: Padders » Wed May 29, 2013 7:59 pm
Thanks if I cannot find one before July I will take you up on your kind offer.
PUM 13
firyembers
Custard Creem
#8 PostAuthor: firyembers » Fri Jul 05, 2013 4:36 pm
Am Home Sunday 8th July.
let me know if you still want the cover
steve.w
#9 PostAuthor: steve.w » Fri Jul 05, 2013 5:14 pm
the 1100r is same as unitrac ..the j and b ones are different !!!!!!!!!!
big green bus
#10 PostAuthor: big green bus » Sat Jul 06, 2013 8:55 pm
elr-21 wrote:Hi there,
YOU ON THE CANS ALREADY STEVEW :roll:
Padders
#11 PostAuthor: Padders » Sat Jul 06, 2013 10:25 pm
All sorted now thanks guys engine built and ready to go into the frame
PUM 13
Users browsing this forum: thebuelligan and 38 guests
