Front Brake Master Cylinder/ Reservoir
Vendetta761
#1 PostAuthor: Vendetta761 » Sat Jul 13, 2013 7:00 pm
I had my brakes overhauled last year on one of my Sts and the level window in the reservoir has started weeping. I cannot find a replacement kit and even if I could not sure how to fit a new one.
Its a shame as it has leaked brake fluid all over the newly painted master cylinder and clamp.
I think replacing it is the only option but then I saw someone [ possibly a Mk2 project] had fitted a rather trick Brembo (?) front master cylinder with a remote reservoir that looked super small and tidy.
Would this work with standard Z1000 ST brakes and lines, if not what are the other options as if I replace the existing unit with another there is a chance of the very same thing happening again.
Any ideas or spare front brake master /reservoirs handy anyone?
_________________
1980 Z1000 E1- ST , 1980 Yamaha XT 250 3Y3 , 1979 Moto Guzzi G5 special , 2000 V11 special, 2009 XT660 X
#2 PostAuthor: Ginger Bear » Sat Jul 13, 2013 7:30 pm
If you want something with a remote reservoir, then a ZX7R master cylinder would work well, should be a 5/8th bore, same as your original........
......... Oddly enough, I might even have one looking for a' new home' :fou
# 104
Vendetta761
#3 PostAuthor: Vendetta761 » Sat Jul 13, 2013 7:40 pm
mmm, thanks GB, got any pix? I will do a quick google search to see if I can see what they look like.
I saw a lovely small Brembo unit somewhere, thought it was on the projects forum somewhere but cannot remember for the life of me, is there anyway of saving your favourite threads anywhere /how.
Anyway , interested in the ZX7R one, just had a look on ebay and it looks like just the thing, what would it take to get it to move to a welcoming home, where it will be much loved and used carefully ?
#4 PostAuthor: Ginger Bear » Sat Jul 13, 2013 7:44 pm
Let me make sure I can find it first, I'll have a look in the morning & report back.
# 104
#5 PostAuthor: Ginger Bear » Sun Jul 14, 2013 4:31 pm
Ok, I've had a good hunt around & all I can find is a m/c with no piston. :roll: You're welcome to that foc, but I can't guarantee it came from a ZX7R.
I have a couple of clutch masters, but no remote reservoir front m/c's. :oops:
# 104
Vendetta761
#6 PostAuthor: Vendetta761 » Tue Jul 16, 2013 7:32 am
ok, Thanks for looking GB, looks like an Ebay hunt for a ZX7 or a GSXR 1000 front master then if I want the small master /remote reservoir look......
Still searching for a spare window seal and method of replacement but I figure the cost of replacement would be the cost of an ebay unit..I will put up a wanted ad just in case, thanks again, V
Redbeard
#7 PostAuthor: Redbeard » Tue Jul 16, 2013 4:03 pm
I will have a look for a gsxr one in the box of bits, it needs the mount I think that attaches the reservoir to the lever. may need the brake lever too but if I can find it you can have it.
1979 Z1000ST
njwmct
#8 PostAuthor: njwmct » Tue Jul 16, 2013 9:34 pm
Fitted a Suzuki GSXR1000K2 front master cylinder /remote reservoir to my Z1000MK2 works well & looks the part.
tightwad
#9 PostAuthor: tightwad » Fri Jul 19, 2013 6:37 pm
ive got a gpz900r which had a crazy / cracked sight glass on the clutch master cylinder, i ended up pushing the plastic one out and getting a piece of watch crystal the correct size to fit in its place, £5.00 of a local market trader in town. I used silicone to seal it in, so far so good about a year on
