Z1000R - anyone local to Faringdon, Oxon can help set up?
martinz1000r
#1 PostAuthor: martinz1000r » Fri Aug 02, 2013 11:06 am
Been a few years in the making but Z1000R finally fired in to life this morning. Good news is the oil leak that caused me to rip the motor down for has been fixed but it definitely needs some tlc beyond me and my tool kit.
Started reasonably ok but spits and pops really badly. I suspect a combination of timing and carb balance to blame.
Motor is GPz1100 Unitrak running APE cams (clearances perfect) via RS36 carbs and Kerker with big bore baffle. Original Kawasaki ignition (Z1000R). Carbs freshly ultra-sonically cleaned. Everything tight and no visible leaks.
I dont own vacuum gauges or a timing light so if any kind sole is willing to help out would gladly exchange biscuits, beer or even cash.
I am in Faringdon, Oxfordshire which is mid way between Swindon and Oxford.
martinz1000r
#2 PostAuthor: martinz1000r » Sun Aug 04, 2013 5:52 pm
Bump.....
tlc
#3 PostAuthor: tlc » Sun Aug 04, 2013 9:14 pm
I'm not an impossible distance away and have the tools you need but……
……I'm not sure what time I could give in the next few weeks.
Happy to lend the bits though.
tedsonthezed
#4 PostAuthor: tedsonthezed » Mon Aug 05, 2013 8:36 am
I've got a timing light, gauges, Colourtune etc which you're more than welcome to make use of. Happy to lend a hand, but don't rely on me for technical ability!
PM me if you want me to take a ride over.
You want how much?
martinz1000r
#5 PostAuthor: martinz1000r » Mon Aug 05, 2013 8:56 am
Thanks for the kind offers. What I am going to do is swap the carbs over from the GPz and see how it runs then. If the problem goes then we know its the carbs and would welcome help / loans.
Given last time it even ran was 2007 there is no desperate rush as winter is almost here :D
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Mon Aug 05, 2013 9:54 am
A mate of mine takes on work for people and know his stuff around these aircooled kwackers and suzy's.
But he is based Tamworth way. If you could get the bike to him he would be able to sort it for you for modest rates. Give us a shout if you want his number.
You say you have rebuilt after a oil leak, just a thought is the Cam timing right and not a tooth out, as it will run but badly!!
martinz1000r
#7 PostAuthor: martinz1000r » Mon Aug 05, 2013 5:56 pm
KWACKERZ1 wrote:A mate of mine takes on work for people and know his stuff around these aircooled kwackers and suzy's.
Ahead of you on that one! Checked cam timing and valve clearances. All OK. Cams have slotted sprockets and whilst not dialled in exactly I set both to mid point thinking that cant be far off.
martinz1000r
#8 PostAuthor: martinz1000r » Mon Aug 05, 2013 5:58 pm
Couple of pictures btw....
kawaman21
#9 PostAuthor: kawaman21 » Thu Aug 08, 2013 7:40 pm
think your front mudguards on backwards,done the same meself!
Pasc
#10 PostAuthor: Pasc » Thu Aug 08, 2013 8:29 pm
Now that's a nice bike.
martinz1000r
#11 PostAuthor: martinz1000r » Thu Aug 08, 2013 8:43 pm
kawaman21 wrote:think your front mudguards on backwards,done the same meself!
Oops!
wild_zed
#12 PostAuthor: wild_zed » Sat Aug 10, 2013 7:54 am
I hope mine looks as good as that when its finished
In my shed
2013 KTM 1190 Adv
2012 MV Agusta Brutale
2011 Ducati Multistrada 1200
2010 KTM990 SMT
1981 Z1000J
1980 H**** CB900F
martinz1000r
#13 PostAuthor: martinz1000r » Sat Aug 10, 2013 12:36 pm
Update....
found one of the rubber hoses between the float bowls had a split in it. Replaced this and also took carb rubbers off, cleaned surfaces and refitted with smear of sealant. Huge improvement immediately so thought a trip up the road might be in order :lol:
Open the throttle and it clears beautifully and god does it fly! It is frighteningly fast and what a noise on that Kerker race baffle! :twisted:
Few immediate teething problems:
Clutch dragging so a little fettling needed
Oil dripping from alternator cover once hot
Spits and farts something rotten at low revs
No speedo (but then there's no cable lol)
So loud i got a glare from the neighbour
Feeling much happier now
:D :D
Z1parR
#14 PostAuthor: Z1parR » Sat Aug 10, 2013 1:08 pm
Good result Martin :up
0172 . Geoff Parr
nw66
#15 PostAuthor: nw66 » Sat Aug 10, 2013 1:25 pm
Cant be to loud!! :D
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
Users browsing this forum: Bing [Bot] and 63 guests
