wheel balancing weights
C Martin
#1 PostAuthor: C Martin » Sun Aug 11, 2013 9:54 am
i am after the type that clips on to the edge of the rim for my z650 c3, i need a 30 gram weight it needs to say K 30 on it otherwise it wont fit the rim as i have tried several but they just dont fit, i have just re furbished my wheels and fitted new tyres and dont want to stick 30 grams of the stick on ones on them
Chris
73 z1, z650c3
ALWAYS LOOK ON THE BRIGHT SIDE OF LIFE
#2 PostAuthor: z1bman » Sun Aug 11, 2013 11:28 am
only the 10g + 20g are still available the 30g is nla
10g weight part no 41075-0014 £5.50
20g weight part no 41075-0015 £5.50
one of each will make up for the 30g which is nla
both in stock at cradley kawaski
njwmct
#3 PostAuthor: njwmct » Tue Aug 13, 2013 6:43 am
If you just refurbished your wheels those crappy clip on weights they will just mark the rims.
Use slimline stick on weights - they make a much better job.
