Greetings,
These two things are about all that's left and I think I had the answers once but the Great Board melt down and my memory failing mean I can't find the info !!
I've search on here and cant find any references anymore. I'm sure I posted and received replies......
so here goes:
1/. Anyone done or seen a cover for the Rev Counter Drive - i have an old Cable with the "outer" cut off and sealed but it doesn't look right really. A cheeky little machined up thing would look better I think.
2/. there's a plug at the rear of the Oil Transfer thing from the Pump/top of the gear box to the oil gallery at the back of the block - some one posted the thread size & pitch M20 or M14 ??
Ta muchly
H
Tacho Gear Blank & a Plug size
Any ideas where I can get these from ?? Been scowering the www for seems like an age looking for these things - a cap to seal off a redundant fuel Tap hole and a replacement for the original tank holder.
I need one with an M16 x 1 female thread. Loads of imperial size ones around but metric ..............
