Tacho Gear Blank & a Plug size
HowieD
#1 PostAuthor: HowieD » Thu Aug 15, 2013 4:18 pm
Greetings,
These two things are about all that's left and I think I had the answers once but the Great Board melt down and my memory failing mean I can't find the info !!
I've search on here and cant find any references anymore. I'm sure I posted and received replies......
so here goes:
1/. Anyone done or seen a cover for the Rev Counter Drive - i have an old Cable with the "outer" cut off and sealed but it doesn't look right really. A cheeky little machined up thing would look better I think.
2/. there's a plug at the rear of the Oil Transfer thing from the Pump/top of the gear box to the oil gallery at the back of the block - some one posted the thread size & pitch M20 or M14 ??
Ta muchly
H
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Thu Aug 15, 2013 4:50 pm
Speak to Debbens about tacho drive blanking plug.
Regards
Steve
#3 PostAuthor: z1bman » Thu Aug 15, 2013 5:13 pm
HowieD
#4 PostAuthor: HowieD » Thu Aug 15, 2013 8:21 pm
Thanks - I looked at that already and i reckon there'll be bother trying to get the old one out. Never been touched in all the time i have owned it - since May 5th 1980.
Keefleaf
#5 PostAuthor: Keefleaf » Thu Aug 15, 2013 8:47 pm
Seem to remember using a Penny and some silicone :wink:
HowieD
#6 PostAuthor: HowieD » Tue Aug 20, 2013 4:46 pm
Any ideas where I can get these from ?? Been scowering the www for seems like an age looking for these things - a cap to seal off a redundant fuel Tap hole and a replacement for the original tank holder.
I need one with an M16 x 1 female thread. Loads of imperial size ones around but metric ..............
DavidZ1R
#7 PostAuthor: DavidZ1R » Tue Aug 20, 2013 4:50 pm
The cap looks like a copper blank plug, a good plumbers merchant does them in 6mm 8mm 10mm 15mm and up to 22mm.
GPRD
#8 PostAuthor: GPRD » Tue Aug 20, 2013 7:20 pm
I did this, just put a ball bearing in and screwed the cover on.
Not fantastic, but I'm sure there'll be worse ideas.
What we got here, is failure to comunicate.
