Any one local to Chesterfield
As above, to come and look at my Z1b.
It runs [poorly]
Carbs done by Gez/Ged
Timing done + new stator plate, plugs etc, etc.
Just need some one in the know to take a look.
Beer tokens waiting.
Gary
It runs [poorly]
Gary
OK, so yesterday I checked the pilots and main jets, all clean and clear.
Rechecked points, timing [with a strobe light]
Fitted new suppressor caps and plugs.
Still the same
Starts fine, runs for about 5 mins, misfires and then splutters to a stop.
Its as though is warming up, electrically ? and causing the issue ??.
I know NOTHING about electrics.
Thanks to those who have responded to my post. But I think I really need a mechanic/electrics guy to diagnose the problem and was hoping to find some one local as I don't have a way of getting it to anywhere!
Gary
Still the same
Gary
- z1000puddin
PaulMceleney
- Chunks
paulmceleney wrote:The same sort of thing was happening on my z1000 it would come to a stop after about twenty minutes of riding. Then I would have to wait for a while before I could ride off again one of the coils was not tight enough so make sure your coils are bolt tight to the frame this may be the cause
OK I will check that .
Thank You
Re: Any one local to Chesterfield
gary557 wrote:As above, to come and look at my Z1b.
It runs [poorly]
Gary
Are the valve clearances ok Gary?That will cause hot running problems if you have a tight valve.
kas750 wrote:gary557 wrote:As above, to come and look at my Z1b.
It runs [poorly]
Gary
Ade,
I have not gone into that yet, as I am not good with 4 strokes! Hence I think I need a spanner man
Thanks for your input.
Gary
gary557 wrote:paulmceleney wrote:The same sort of thing was happening on my z1000 it would come to a stop after about twenty minutes of riding. Then I would have to wait for a while before I could ride off again one of the coils was not tight enough so make sure your coils are bolt tight to the frame this may be the cause
Thank You
Just been and checked, all are tight.
As an aside to this, the frame has been powder coated, do the coil bolts need to go to bare metal?, ie could the powder coating be an issue at this point?
Gary
