33mm Mikuni Smoothbores set up advice needed
Padders
#1 PostAuthor: Padders » Sun Sep 15, 2013 4:31 pm
Hi I have a set of 33mm smoothbores I am fitting to a standard Z1100R motor running K&N oval filters and a 4 into 1 free flowing exhaust. Any ideas on jetting out there to give me a starting point would be much appreciated.
PUM 13
KWACKERZ1
jetting.
#2 PostAuthor: KWACKERZ1 » Sun Sep 15, 2013 6:36 pm
Ian
The mikuni 33 manual recommends,
kz1000/1100
Main jet 127
Air jet 1.2
jet needle 6dj30-4
needle jet 261-0.6
Pilot jet 17.5
throttle valve 1.5
Air screw 3/4 out
However a trick with these is to use a 0.06 air jet which gives much better low speed response and allows a smaller main jet rating.
My 1075 motor with std cam runs well on
the above settings but with a 120 mains and a 0.06 air jet. But the airscrew is 1.5 turns out.
(between suzy's and kwackers the throttle valve cutaway is slightly different so make sure you're 33's have the 1,5 cutaway)
Padders
#3 PostAuthor: Padders » Sun Sep 15, 2013 6:45 pm
Thanks for the information will check the carbs tomorrow. Do you know the best place to get the parts from.
PUM 13
Holeshot
#4 PostAuthor: Holeshot » Sun Sep 15, 2013 9:46 pm
Oz at Zed Parts has been brilliant for me.
Top fella :)
KWACKERZ1
#5 PostAuthor: KWACKERZ1 » Mon Sep 16, 2013 6:44 am
Allens i get my stuff from they seem to have reasonable stock,
http://www.allensperformance.co.uk/
