Z900 A4 Bike Firing
Hammo
Z900 A4 Bike Firing
#1 PostAuthor: Hammo » Mon Sep 16, 2013 1:00 pm
Had the top end overhauled a couple of month back , since then the bike is not ticking over very well , and now has an intermittent firing problem on no 2 cylinder including backfiring any idea,s guys will be appreciated . :cry:
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Mon Sep 16, 2013 2:10 pm
What did the overhaul entail?
Check your compression on all cylinders especially number 2.
I assume you have done the valve clearances and double checked the timing after the rebuild?
PaulMceleney
Chunks
#3 PostAuthor: PaulMceleney » Tue Sep 17, 2013 6:02 pm
If your valve timing out by one tooth it will start but run rough
