Moving a Zed engine
KeithZ1R
#16 PostAuthor: KeithZ1R » Thu Sep 26, 2013 9:19 am
[quote="Pigford"]+ 1.... but mines a sporty Yellow version :wink:
what's that sprocket all about Piggy ?............ he asked curiously
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Jay1969
#17 PostAuthor: Jay1969 » Thu Sep 26, 2013 10:31 am
It's for preventing wobbling and weaving when carrying
a 180mm rear tyre Keith :D
Gavin
#18 PostAuthor: Gavin » Thu Sep 26, 2013 11:14 am
KeithZ1R wrote:Gavin I have two, you are welcome to one, just not how you would get it :)
Cheers for the offer, as you say its picking it up that would have to be thought about .
I have now ordered one like i posted a link to in an earlier message.
Presently strippng the bike down so i can lay it on it's side then lift the frame off the engine.
Z1000 MK2
Z1300 DFI
#19 PostAuthor: Pigford » Thu Sep 26, 2013 5:57 pm
KeithZ1R wrote:what's that sprocket all about Piggy ?............ he asked curiously
Keith...
http://www.z1ownersclub.co.uk/forum/vie ... 90&start=0
Take a butchers at that lad :wink:
Mark Stratton
#20 PostAuthor: Mark Stratton » Fri Sep 27, 2013 12:33 pm
I use one of these, saved from a skip at a disabled living aids company and tested it to 250kg once in place. The lazy mans way :lol:
Even has power traverse :wink:
FOZ1A
moving a z engine
#21 PostAuthor: FOZ1A » Fri Sep 27, 2013 3:42 pm
http://www.ebay.co.uk/itm/Dragbike-KZ-Z ... _38wt_1172
Here you go! I reckon Rob (1015) could knock these up in his sleep!
foz
Gavin
#22 PostAuthor: Gavin » Fri Sep 27, 2013 4:58 pm
Gavin wrote:Just found this
http://www.coopersofstortford.co.uk/src ... tAodxBQApA
I will let you all know what it is like when it arrives.
Although when you press buy, it say that it could be upto 28days delivery
Cannot criticise the delivery, it arrived this morning
Z1000 MK2
Z1300 DFI
Garn 1
#23 PostAuthor: Garn 1 » Fri Sep 27, 2013 9:27 pm
Gavin, I like your selection of the trolley and I'm sure it will let you move your engine around the garage or work-shop easily. However, you may have to leave your motor hanging around for some time.... If you have, I found it easier to store on a bench, hence, I remove the sump/oil-pan and the oil-pump so that the engine sits flat and easy to store.
I usually find a flat soft plate to sit the engine on, such as a cork place mat .. That seals out the dust and has a minimum foot print.
Regardz
Gavin
#24 PostAuthor: Gavin » Fri Sep 27, 2013 9:36 pm
Garn 1 wrote:Gavin, I like your selection of the trolley and I'm sure it will let you move your engine around the garage or work-shop easily. However, you may have to leave your motor hanging around for some time.... If you have, I found it easier to store on a bench, hence, I remove the sump/oil-pan and the oil-pump so that the engine sits flat and easy to store.
Regardz
Good point got to go to b&Q tomorrow I will get some floor tiles
Z1000 MK2
Z1300 DFI
