Hi
Does anyone know the part number and name for the rubber mounts that fir in the front of J series engines?
Alternatively the sizes needed to make up some metal ones
Engine Mounts
Hi Mark you need
2x 920751272 upper engine mounts
4x 920751274 side engine mounts
2 x 920751273 lower engine mounts
I would definitely replace with new if you have the engine out and are doing a full rebuild the difference with new ones against old worn rubbers is noticeable. You can get away without the side mounts if yours are okay.
Got all mine from Z Power next day delivery
PUM 13
