Default pilot air screw setting on VM26's
Paul Whitehouse
#1 PostAuthor: Paul Whitehouse » Tue Oct 22, 2013 8:32 am
Hi, seeing as I had no previous settings to work to....does anybody know the number of turns from lightly seated that the pilot air screw (on the underside of the carbs) needs to be backed off to on a set of VM26's to take it back to a `default` setting? Cheers.
If it's too loud....too bad.
scott
Junior Section leader
#2 PostAuthor: scott » Tue Oct 22, 2013 11:07 am
I think it's 1 and a half
Z1parR
#3 PostAuthor: Z1parR » Tue Oct 22, 2013 7:53 pm
1 and a quarter out + or - an eighth .
0172 . Geoff Parr
#4 PostAuthor: z1bman » Tue Oct 22, 2013 8:17 pm
just get yourself a colour tune if you don't already have one. only way of getting the mixture something like without having a dyno run
Paul Whitehouse
#5 PostAuthor: Paul Whitehouse » Tue Oct 22, 2013 9:37 pm
Cheers guys....I have found a manual that states 1 1/2 turns, as Scott mentioned....I'll start at this setting and see how she runs.
scott
#6 PostAuthor: scott » Wed Oct 23, 2013 6:57 am
Z1bman is right.....use a colour tune.....it worked for me
Paul Whitehouse
#7 PostAuthor: Paul Whitehouse » Wed Oct 23, 2013 8:12 am
Managed to borrow a colour tune from a chap at work...I'll get everything to basic settings and give it a go...thanks guys.
tlc
#8 PostAuthor: tlc » Wed Oct 23, 2013 9:27 am
Also note that these are fuel screws and not air.
