oil leak
justin taylor
- Regular Poster
oil leak
Ihave an oil leak from the front left side casing(alternator cover),it seems to be dripping from where the wires come out at the bottom of the casing.Firstly what are the wires and secondly how do i stop the leak?Any advice will be greatly appreciated.
Justin, this is the most common leak on a Zed
The wires are from the alternator, they pass through a rubber grommet which after time perishes & hence the leak
Best way is to replace grommet, available from Z power to name but one supplier. Or, remove casing ( tilt bike to right side as a little oil may tip out ) and thoroughly clean are with de-greaser (Gunk/Jizer etc). when clean & dry, use silicon sealer or good gasket goo, and re-assemble.
Good luck
Good luck
- london calling
justin taylor
- Regular Poster
oil leak
Thanks for the help lads.Z Power sell an alternator cover grommet(part no 92075 alt)is this the one i need?What is the procedure to fit it?Thanks again
- london calling
The key to success here Justin is making sure that the wires/grommet are completely degreased and dry. Recently did our kids for him, degreased with cellulose thinners put silicon around wires/grommet (make sure you force silicon all around wires) new gasket and hey presto no more leak. Previous owner had tried to cure numerous times without success and told my brother it was 'just one of those things and all zeds do it'- utter rubbish, its all in the prep'.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
justin taylor
- Regular Poster
oil leak
Many thanks for all your help lads.When you say fit a new gasket do you mean the alternator casing gasket?Ihavent been in there yet so i dont know what i will find.Thanks.
- rickman CRR
Hi Justin,
I had a similar problem with my Z1. However I managed to reuse the original square grommet seal by buffing up the mating faces with emery paper, degreased it and applied a small amount of sealant with new alternator gasket.
You'll probably find the old gasket will stick and break up when you pry off the casing. Careful cleaning up of the facings with a blunt scraper will be needed before reassembly.
Take your time, keep it all clean. Good luck.
