keys
tightwad
keys
#1 PostAuthor: tightwad » Tue Nov 05, 2013 9:22 pm
hi all, would i be right in thinking the lockset should all be the same key, bike is z1000 a2. ign/ tank/seat all use the same key (number is in the 700,s) but steering lock is totally different number(400,s). does,nt look like the lock has been changed/messed with,
where would i get a key to suit it
thanks ken
timyoungman
#2 PostAuthor: timyoungman » Wed Nov 06, 2013 7:49 am
You can get a key from these people for about $12.50
http://www.key-men.com
or try
www.ashfieldsecurity.co.uk
or post the number of the key you want ...someone might have a spare.
njwmct
#3 PostAuthor: njwmct » Wed Nov 06, 2013 8:55 pm
Try:
John Richard Security Products - tel 0151 342 2318 /4074
(202a Pensby Road, Heswall, Wirral, Merseyside.
I gave him the key no. & he sent me 2 cut keys on the correct shaped blanks - £11.50 delivered.
tightwad
#4 PostAuthor: tightwad » Thu Nov 07, 2013 8:55 pm
thanks for replys as to where to get keys from. But is it right that there should be 2 different keys for the lockset :?:
Rhencullen
#5 PostAuthor: Rhencullen » Thu Nov 07, 2013 9:27 pm
tightwad wrote:thanks for replys as to where to get keys from. But is it right that there should be 2 different keys for the lockset :?:
No Ken - Ideally the same key should work all the locks....... sounds like the bike's had a different steering lock fitted at some point ( or even reframed :shock: )
tightwad
#6 PostAuthor: tightwad » Fri Nov 08, 2013 8:32 pm
thought they should use one key martin, like you say might have had new lock fitted or its not the original bottom yolk :?? not that im worried, just curious
