Oil Lines
Muddychris
Oil Lines
#1 PostAuthor: Muddychris » Sun Oct 14, 2007 11:54 am
Hi
can some kind sole tell me where the oil lines pass by the carb and the back of the engine. Have tried several combinations and either the lines seem to tight or thay stop the throttle linkage from working. What a BAST**D of a job getting them bleeding carbs on and off is. Dont know how much more grief them rubbers are going to take.
Chris
Experience is something you don't get until just after you need it.
#2 PostAuthor: Pigford » Sun Oct 14, 2007 2:54 pm
Chris, I pass mine thru the frame, by the head stock, along the spine and looped over top of carbsthen back round to take offs :wink:
london calling
#3 PostAuthor: london calling » Sun Oct 14, 2007 3:11 pm
Chris,the factory oil lines run up between the carb manifolds.There should be a clamp between each pair of carb rubbers/manifolds to holf the oil lines in place.
Jack
Muddychris
#4 PostAuthor: Muddychris » Sun Oct 14, 2007 4:04 pm
Thanks gents thats sorted that problem. Easy when you know how I suppose.
Big thank you gents
Chris
Users browsing this forum: Noblester and 33 guests
