Electrical issue.
Electrical issue.
Hi all
wonder if any of you fine folk can assist me with the reason my main fuse blowing on my 1976 kz900. It does not blow right away only after 20-30 miles?
Thanks in anticipation
Mick
Mick
Z900, Tuono RSV 1000, XL600R, DT100, KDX125, CL350
- Fred the Zed
Check the white wire from the fusebox to the ign switch. Often they rub on the headstock or headlamp bowl. Also the insulation may look ok but wire strands break within causing higher resistance.
Look at the fuse condition it will give you clues
if its disintegrated or vaporised the clue is a bad and direct short, discoloration or deformation in the element before fracture suggests a resistive leak that is weakening the fuse by overheating a good way of checking is to get your multi meter in series with fuse and see what current is passing through it ( the fuse ) its all good practise for 30 year old bikes
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Thanks men
this will give me some ammo to try and rectify the problem when I get back from Nigeria next week.
Thanks again.
Maybe paypal will then forward my membership fee from the UK as its not doing it from over here "the scam country of the world"???
Thanks again.
Users browsing this forum: Bing [Bot], KeithZ1R and 49 guests
