Spokes and wheels
Spokes and wheels
Hi can anyone advise. I purchased a set of original wheels for my KZ900 A4.
I have had them stripped and re chromed and they look fantastic. I purchased new spokes and have laced the rear wheel no problem. But the front pattern is not working out as the spokes are falling short of the holes!
This tells me that the spokes are too short or the rim too big. I checked the spoke spec and measured them and they are 180+mm however I just measured the rim outside edge and it's 20 inches!!!! Is that right?
I thought it should be 19 and would answer the problem.
But why 20 inches? Is there a 20inch wheel for the z's and is it ok to use with longer spokes?
Bike now finished what a joy!
- DogsbolloxofZ1B
What a relief and thanks for all the comments. I guessed it had to be the spokes when I got home and measured the rear 18 inch it came up 19 on the outside an inch bigger so it kind of made sense.
New spokes then, definitely the cheaper of the options.
Wayne1960 wrote:What a relief and thanks for all the comments. I guessed it had to be the spokes when I got home and measured the rear 18 inch it came up 19 on the outside an inch bigger so it kind of made sense.
Especially after the rechroming!!!
Jimmock.
I hate people I don't like !
- mick znone
Thanks I did see that. Mine are a right 180mm I purchased from US! I guess it's the overal lengh of the metal you measure and that 4mm wil make a differance.
I need to try and find the same as the rear which don't have the brass nuts.
Any ideas.
Any ideas.
Users browsing this forum: No registered users and 111 guests
