z1000j back fire
ChrisBrooks
z1000j back fire
#1 PostAuthor: ChrisBrooks » Fri Oct 26, 2007 11:23 am
Just decided to start refurbing the bike so I went to start it(after 3 years)
It went but boy was it back firing out of every orafice . Could this be bad fuel or something else. + what manuals are best I have a clymac which is not specific. :?:
#2 PostAuthor: chrisu » Fri Oct 26, 2007 1:19 pm
If you didn't drain all the fuel out of the carbs and tank an put fresh in they i'd start there...............
floydsz1
#3 PostAuthor: floydsz1 » Fri Oct 26, 2007 3:58 pm
fuel only last a few months b4 it starts to go off, carbs will prob need a full strip and possibly ultrasonically cleaned. have a sniff inside the petrol tank, i bet it smells like vinegar. i always drain the carbs/tank when parking my bikes up over the winter.
london calling
#4 PostAuthor: london calling » Fri Oct 26, 2007 3:59 pm
You might want to remove your carbs and get them properly cleaned if they've been stood for 3 years with stale petrol in 'em.
Also make sure that you've got a good quality battery which is fully charged as well,either a Varta or Yuasa.
Always fit DENSO plugs as they seem much more reliable the the NGK ones.
If you need to borrow a genuine Kawaaki workshop manual,PM your postal details and I'll get 1 in the post to you Chris :D
Jack
#5 PostAuthor: Rich » Fri Oct 26, 2007 5:50 pm
check to make sure the ignition adv/ret isn't stuck
Manuals and info For J
#6 PostAuthor: Al » Sun Oct 28, 2007 12:47 pm
Hi Chris, i live three miles from you i have both manuals and lots and lots of info. What do you need????
Users browsing this forum: Noblester and 35 guests
