Bearings for CMA wheels
Fred the Zed
#1 PostAuthor: Fred the Zed » Wed Feb 26, 2014 8:01 pm
Hi
I have a set of CMAs for my Z1R, that need refurbishing. I'll change the bearings and dust seal(s) as part of the process for reliability's sake, but I'm unsure of the sizes. Anyone done this before who can recommend a supplier?
Fred
Paid Up Member
hillbilly
#2 PostAuthor: hillbilly » Wed Feb 26, 2014 8:15 pm
there should be numbers on the edge of bearings.
andyb1962
#3 PostAuthor: andyb1962 » Wed Feb 26, 2014 9:28 pm
If no's not visible measure
OD ID and thickness then look it up on a bearing comparison site
I have a book if ya get stuck I'll look it up at work and give you the skf equivalent bearing Generally your better off with sealed type
Andy :wink:
neilbarrett
#4 PostAuthor: neilbarrett » Wed Feb 26, 2014 10:22 pm
or take the old bearings to the supplier
#5 PostAuthor: Al » Wed Feb 26, 2014 10:23 pm
I get all mine from here but then it is local.
They also supply bearings by application ie. for a given bike so may be worth a call.
http://shop.marksman-ind.com/on-road-mo ... -871-c.asp
martinz1000r
#6 PostAuthor: martinz1000r » Thu Feb 27, 2014 9:24 am
i got mine off ebay. Go for quality though! If you cant see the size on the bearing then measure outer diameter, inner diameter and width. I have CMA wheels so will try and find the receipt for all the bearings and get the sizes off that.
KWACKERZ1
simply bearings
#7 PostAuthor: KWACKERZ1 » Thu Feb 27, 2014 10:11 am
http://simplybearings.co.uk/shop/
You can pick how much you want to spend and search by sizes, quick turnaround as well.
Fred the Zed
#8 PostAuthor: Fred the Zed » Thu Feb 27, 2014 7:12 pm
All good advice!
Cheers fellas
All the best
Fred
Paid Up Member
Users browsing this forum: No registered users and 111 guests
