Exhaust collets
Toyboy
Exhaust collets
#1 PostAuthor: Toyboy » Mon Mar 10, 2014 5:19 pm
Does anyone happen to know the depth of the exhaust collets on a z900?
Garn 1
#2 PostAuthor: Garn 1 » Sun Mar 16, 2014 4:46 am
Toyboy, presuming by the collet, you mean the two pressed metal insert halves that lock-in the exhaust gasket, by means of the exhaust 6mm manifold bolts....... I make them 27.5 mm long. This was the measurement for an aftermarket set that is suitable for Z1, Z1A, Z1B & Z900.
The recess in the finned exhaust flange that pushes the exhaust-pipe home via these collets is 2.5mm.
Toyboy
#3 PostAuthor: Toyboy » Sun Mar 16, 2014 5:14 pm
:up Thanks
