Ohlins Top Rubber Bushing
Jumbo
#1 PostAuthor: Jumbo » Sat Mar 22, 2014 6:52 pm
Hi does anyone know where these can be bought from. It is just the rubber bit that fits inside the top mount. Has anyone bought the general sets from ebay. Such as these ?
http://www.ebay.co.uk/itm/SHOCK-ABSORBE ... 1e87e7398e
LE to JOG on a z900
P.U.M.
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Sat Mar 22, 2014 7:25 pm
Have a look at your local bearing supplier or simply bearings web site you should be able to get something form them to fit.
gpjes
#3 PostAuthor: gpjes » Sun Mar 23, 2014 9:07 am
Hi, if they're buggered then you need the correct internal bushing diameter, I bought some from a someone who deals in motorcycle shock refurbs, I needed bigger ones than the XJR items for my ST. The ohlins I had we're from a said Yam, ok on the bottom but too small at top, you can get poly bush ones, but they are naff colours and would look odd! Gen items can be sourced at mosickle suspension places just take care when fitting, they aren't mega bucks, mine cost twelve quid each,fitted. :D :D :D
More Smiles Per Mile
Users browsing this forum: Stevo1015 and 23 guests
