Fuel tap sealing tape
Fred the Zed
#1 PostAuthor: Fred the Zed » Mon Mar 24, 2014 6:02 pm
I've got a Pingel tap on my shed. It says to use tape to seal the screw thread but PTFE tape appears to be perishing. Am I using the right stuff or is there a different tape I should be using?
Fred
Paid Up Member
#2 PostAuthor: z1bman » Mon Mar 24, 2014 6:31 pm
mike_p
#3 PostAuthor: mike_p » Mon Mar 24, 2014 7:12 pm
I used PTFE tape on mine and so far it's ok......Pingel actually recommend it in their fitting instructions. I must admit I was a bit hesitant but googled it and found plenty of info to confirm it's ok so just slapped it in :D
jphaynes669
#4 PostAuthor: jphaynes669 » Mon Mar 24, 2014 8:31 pm
You can also use boss white jointing compound, the gas board use it and its resitant to almost anything..used it loads with no dramas.
Jeff.H
z1000puddin
#5 PostAuthor: z1000puddin » Mon Mar 24, 2014 9:42 pm
I did not put any thread sealant on my pingle.
I just made sure that the threads on the tank boss were clean & in good order.
Just remember to fit the sealing seat washer ( my first attempt I left mine in the packaging :oops: )
No issue so far.
stu
Zed til Dead
