JMC adjustment
Hobbo
International Rep
JMC adjustment
#1 PostAuthor: Hobbo » Sat Feb 22, 2014 1:02 pm
Guyzx
you boyz with jmc swing arms how do you adgust cams for chain alignment cant see any notches ??
Phil
International Rep
#2 PostAuthor: Ginger Bear » Sat Feb 22, 2014 1:15 pm
:pop ......................................................
............................... :boom :boom :boom :boom :boom
# 104
Hobbo
International Rep
yo
#3 PostAuthor: Hobbo » Sat Feb 22, 2014 1:23 pm
Mark
Give up ya t**t
International Rep
Taffus
#4 PostAuthor: Taffus » Sat Feb 22, 2014 1:35 pm
ok, given up...... joke is old now
#5 PostAuthor: Ginger Bear » Tue Mar 25, 2014 6:41 pm
Phil,
I've just knocked these up;
M8 bolts with the heads cut off & a bit of steel flat bar, left over from Coldsummers tennis court repairs. :sou
# 104
PaulMceleney
Chunks
#6 PostAuthor: PaulMceleney » Tue Mar 25, 2014 8:06 pm
There is no notches to see, you need a tool like Steve made I had one made for me when you turn the cams you can measure from the top of the swingarm to the top of the bar both sides, both need to be in the same position, the tool I have fits snug into the cams
#7 PostAuthor: ADRIAN H » Tue Mar 25, 2014 8:49 pm
Ginger Bear wrote:Phil,
I have a pair very similar to those. Mine are made from M8 Rawl bolts, through some M10 Ali bar.
rpeters
Bristol's "H" Hoarder
#8 PostAuthor: rpeters » Tue Mar 25, 2014 9:04 pm
Yep Ging, I have a pair exactly the same.....they work a treat :lol: :lol:
paid up member
jphaynes669
#9 PostAuthor: jphaynes669 » Tue Mar 25, 2014 9:06 pm
I have made a similar tool as shown, but then I use a protractor and set both sides at the same angle until the correct tension is set. Its a bit of a fiddle but spot on alignment is guaranteed. :D
Jeff.H
njwmct
#10 PostAuthor: njwmct » Wed Mar 26, 2014 6:25 pm
Even if you measure the position of each eccentric in relation to the swingarm very carefully it doesn't mean that the bikes wheel alignment (front wheel to rear wheel) is correct.
Even on a modern bike you can adjust your chain & line up the adjuster marks equally & the wheel alignment is highly likely to be out.
The only way to get accurate wheel alignment is with a laser set up.
http://www.njwmotorcycletyres.co.uk/accu-track.htm
