Twin Discs
harri183
Twin Discs
#1 PostAuthor: harri183 » Fri Sep 27, 2013 7:38 am
Can any one help, are the brake pipes from the spliter to the caliper the same on both sides as in same length on twin discs for a Z1b. Many Thanks.
Garn 1
#2 PostAuthor: Garn 1 » Fri Sep 27, 2013 10:38 am
The pipes & hoses from the splitter to the calipers are the same lengths, however, the pipe shapes are mirror images of each other.
RegardZ
#3 PostAuthor: ADRIAN H » Fri Sep 27, 2013 11:01 am
Garn 1 wrote:The pipes & hoses from the splitter to the calipers are the same lengths, however, the pipe shapes are mirror images of each other.
RegardZ
+1 :wink:
wilsonsjw11
#4 PostAuthor: wilsonsjw11 » Fri Sep 27, 2013 11:15 am
Yes.
The brake hoses from the splitter are the same.
The steel lines are as mentioned in the earlier post,GEZ635 on here can supply both as OEM finish.
Regards
Steve
G
#5 PostAuthor: G » Tue Apr 01, 2014 8:37 pm
Can anyone confirm what the O.E.M. finish was please i.e. were the threaded connection finished in a yellowish pasivet similar to spoke nipples ? Cheers
tlc
#6 PostAuthor: tlc » Wed Apr 02, 2014 5:07 pm
I'm pretty sure the nuts are yellow passivate whilst the pipes are silver.
Al Marshall or Gez365 will confirm
G
#7 PostAuthor: G » Wed Apr 02, 2014 5:11 pm
Cheers tlc appreciated , got my clocks with Al at the moment so will be in touch with him
Users browsing this forum: r3sc, wilsonsjw11 and 49 guests
