charging issue now fixed
Mark Tiller
#1 PostAuthor: Mark Tiller » Wed Apr 16, 2014 7:12 pm
15.25v...This seems too high to me?
07962421462
#2 PostAuthor: z1bman » Wed Apr 16, 2014 8:30 pm
YES ITS WAY TOO HIGH
Mark Tiller
#3 PostAuthor: Mark Tiller » Wed Apr 16, 2014 8:44 pm
I though it should be 13.8v to 14.5v, is that right?
07962421462
KeithZ1R
#4 PostAuthor: KeithZ1R » Wed Apr 16, 2014 8:57 pm
that's all I can ever get and its less with the lights on
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#5 PostAuthor: z1bman » Wed Apr 16, 2014 9:27 pm
MORE THAN 14.6 VOLTS & IT WILL BOIL THE BATTERY DRY & POSSIBLY SPILL ACID OUT THE OVERFLOW & DAMAGE YOUR CHROME WORK
Mark Tiller
#6 PostAuthor: Mark Tiller » Wed Apr 16, 2014 9:35 pm
Cheers, its a motobatt so no acid to worry about. I haven't run it for any length of time only enough to take the readings. I have emailed Zpower about it
07962421462
Garn 1
#7 PostAuthor: Garn 1 » Thu Apr 17, 2014 2:10 am
Mark, make sure you check with battery fully charged (say 12.7 Volts).
With motor warm take her up to 4000rpm and see if doesn't go over 15.5 V.
Check your "Digital" volt meter against another.
It might only be , just on the high side at 15.25 V. I would accept 14 .75 V
Check also with lights on!
Mark Tiller
#8 PostAuthor: Mark Tiller » Thu Apr 17, 2014 6:44 pm
Garn.... Motobatt Battery is fully charged and I tested with two separate Fluke meters, the old rec and reg have both been removed from the bike, I tried another mini loom with the 4 sockets on and it was the same voltage peaking at 15.25v....I cant remember if I had the lights on or not but will test it in the morning.
I'm a bit worried it could destroy the Dyna S if I run it for any length of time.
I emailed Dave at ZPower who is checking it with his electrical expert, he says he has never had one fail before, this one is working as it is 13.5 at tickover but raises too high.
What else could it be other than the reg/rec?
07962421462
#9 PostAuthor: z1bman » Thu Apr 17, 2014 7:13 pm
run a separate wire from the battery positive to the brown wire on the regulator & see if this reduces the voltage
#10 PostAuthor: Pigford » Thu Apr 17, 2014 7:26 pm
z1bman wrote:run a separate wire from the battery positive to the brown wire on the regulator & see if this reduces the voltage
Is that the "switched" live sensor wire :?:
I got hold of a NOS Newtronics Reg/Rec for me Harris - as I wired the bike meself I was a bit apprehensive, especially as I also fitted a lithium battery - but so far all seems good. I got 13.5 V at about 3000/3500 rpm. Really need to do some longer trips (>5 miles) to make sure :|
#11 PostAuthor: z1bman » Thu Apr 17, 2014 7:29 pm
yes brown is the switched live
Mark Tiller
#12 PostAuthor: Mark Tiller » Fri Apr 18, 2014 9:15 am
hi again all...further advice required
12.7 ign off
12.2 ign on
12.0 ign on lights on
RUNNING...
14.2 at tickover lights off
13.2 at tickover lights on
at 4000rpm
15.3 lights off
15.2 lights on
07962421462
Mark Tiller
#13 PostAuthor: Mark Tiller » Fri Apr 18, 2014 9:20 am
which wires dos the new unit measure across?
07962421462
Mark Tiller
#14 PostAuthor: Mark Tiller » Fri Apr 18, 2014 4:55 pm
Think I have cracked it, after z1bman suggested running another wire direct from the battery which improved it, I decided it must be volt dropping across all the joints and therefore the reg/rec not seeing what was directly across the battery, voltage was also low at the coils too, so spent the morning doing the Wired George thing which seems to have improved things, and ran an extra earth in to the black/yellow that was left unused... i'll post some readings after charging the battery
07962421462
#15 PostAuthor: z1bman » Fri Apr 18, 2014 5:25 pm
was it garn who suggested the brown wire ?? :( :(
