cant get the carbs to stop overflowing on my z900a4
the bikes been stood for about 6 month
stripped the carbs,cleaned em,everything seems fine,put em back on,petrol pissing ot the overflows!
there fitted with dyno jet,engines a 1075 wiseco,do i persivere or change the carbs to summit else?
mikuni carbs
kenny z9fighter
Steve Cooke
- ZedHead
Kenny, I had a similar problem and I have heard of others with the same.
The problem could be a hair-line crack down the length of one or more of the brass overflow tubes, inside the fuel bowl.
Very hard to see unless looking for it. I was amazed that it would cause such leakage. I think I cured it with a thin piece of plastic sheathing, or was it solder. The crack usually continues thru into the bottom of the fuel bowl.
kenny z9fighter
i've took the carbs of again,cleaned everything,put the floats in a bucket of petrol,they didnt sink,bent the tab up a wee bit more,put them back on the bike,got really cold and came in for a coffee,i'll put the tank on tommorrow and give it a go,the taps not a vacum,just the on,res and of type.what i have noticed is i put a gallon in the tank,in the on position nothing comes out,on reserve only a small drop seems to come out one of the outlets,is this normal?do you need at least half a tank to get sufficiant fuel?
kenny z9fighter
Users browsing this forum: Noblester and 38 guests
